XBOX 360 owners, help needed............
Just put it on a bit ago and had it on dashboard when i saw 3 (i think) red lights flash up for a bit then go. Done the usual google seach and it indicates a hardware failiure although now it has gone and not seen it since. From what i read this seems as though its not good though long term.
Only got mine Xmas day and what i want to know is did any of you lot who've had the permanent red ring of death get a few reds flashing before hand? Cheers.
I had RROD last month, my 360 lasted 2 years! When i saw the lights it was three red ones on permantly. I turned it off/on/off/on but nothing, it was totally dead! I called Microsoft and they fixed it free of charge.
If I was you as its only 2 months old i`ll take it back to the shop
HTH
Lee
HTH
Lee
Check that the video cable is securely plugged in at the back as it can cause the console to flash red. If that does not solve it, take it back to the shop you got it from as most offer an over the counter swap for machines under 1 year old.
Kiran1600E
11
Oct 2, 2015 11:35 AM
rsguy
44
Sep 29, 2015 03:29 PM
