can i use this.......
to replace my existing fuel lines under the car? the main feed from the fuel pump and the return pipe from the front. i'm asking this as all the fuel lines under my car have rotten away and i have leaks.
http://cgi.ebay.co.uk/10MM-BRAIDED-F...QQcmdZViewItem
if you think i cant use tis what else do you suggest. cheeRS
Christian and Beccy
Aug 15, 2009 08:29 AM
