Would this spec be a genuine 450bhp
Old Feb 29, 2008 | 09:52 AM
Jasesapphy's Avatar
Jasesapphy
Default Would this spec be a genuine 450bhp
Long Stud 200 Block Cosworth Race Bearings and weight matched rods
Ported polished head, with matched ports on 8:1
BD14 Inlet and Standard Exhaust & Iskys
WRC Gasket
Roller Bearing T38 on Air Injectors
Would that do a genuine 450bhp and simlar Torque
Old Feb 29, 2008 | 10:25 AM
- Sim -'s Avatar
- Sim -
should be ok for that kind of power.
to get some more power for later tuning, get a GT3076 from Martin (Reyland)
Old Feb 29, 2008 | 10:31 AM
Dan's Avatar
Dan
No.
Oh, and ring me back you slag!
Old Feb 29, 2008 | 01:54 PM
Dan's Avatar
Dan
Bump
Old Feb 29, 2008 | 02:01 PM
bud-weis's Avatar
bud-weis
Football Cwazy
Who's T38? if it's a TT one then i'd say yes....although i doubt you'd get 450lb/ft tbh.
Old Feb 29, 2008 | 02:03 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Depends what boost, he doesnt mention it.
Boost=Torque
Old Feb 29, 2008 | 02:09 PM
bud-weis's Avatar
bud-weis
Football Cwazy
Boost=Torque
Agreed, but i'm sure the T38 isn't great for holding or even peaking mega high boost....can't remember if it was due to back pressure or whatever though.
Old Feb 29, 2008 | 02:17 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Ive seen people running 35psi+ on TT T38s IIRC, YUM etc did...
Old Feb 29, 2008 | 02:25 PM
bud-weis's Avatar
bud-weis
Football Cwazy
Did he make 450lb/ft then? i seem to remember it being 460odd bhp.
Lets hope it's the TT turbo then, the UT one isn't that great lol.
NEIL A's Avatar
NEIL A
Think bud-wise is thinking of the UT T38 that isnt ment to give massive torque figures but have seen them used with a 36psi+ spike.
If there was enough boost then thatspec should give close to 450 if its on a TT T38 think the UT one is only rated to around 430 but will do slightly more if pushed hard.
Old Feb 29, 2008 | 02:29 PM
bud-weis's Avatar
bud-weis
Football Cwazy
yeah tbh i can only be sure of the UT one, which on my old car mapped by Karl was running 424bhp and 390lb/ft (peaking 2.1bar and holding 1.7).
same car mapped by MAD i 'think' made 442bhp and 368lb/ft ( not sure on boost levels tbh .
In answer to the original question though, i think that it will get as near as dammit to it anyway.
Old Feb 29, 2008 | 02:33 PM
Dan's Avatar
Dan
Jase hasn't got a T38 yet, so if it's the TT one he needs and not the UT one then i'm sure that's what he'll go for
He is a proper hater of lag though hence why he's mentioned the roler bearing core
NEIL A's Avatar
NEIL A
Hope it does make 450 as its a similar spec to mine apart from the comp is much higher and thats the sort of power im looking for from my T38.
Old Feb 29, 2008 | 02:43 PM
Dan's Avatar
Dan
You've gone low comp have you Neil?
Old Feb 29, 2008 | 02:46 PM
Danny @ Enhanced Performance's Avatar
to be honest i dont like the t38s cos your inbetween 400 and 500 bhp teritory. with the engine spec and comp ratio id go for the t4 type gt30 roler bearing and 55lb siemens.no lag close to 500bhp and over 400lb/ft easy and al that with 2 bar or less
NEIL A's Avatar
NEIL A
Yip im lower than 8.1:1 a bit lower than 7.2:1 aswell.
Old Feb 29, 2008 | 02:54 PM
Dan's Avatar
Dan
Sounds good, he's not chasing numbers though so a T4/500bhp isn't essential Think Jase has already got 55lb blacks too
Neil, LOWER than 7.2:1!? Why?
Old Feb 29, 2008 | 03:04 PM
Staffi's Avatar
Staffi
My UT T38 only made 355 ft.lb @ 2.1 bar.........YUK...........
Old Feb 29, 2008 | 03:27 PM
My T3/34, made 330lbft at 2200rpm, and holds 330lbft all the way to 6300rpm, holding 1.5 bar boost.
Old Feb 29, 2008 | 04:12 PM
Dan's Avatar
Dan
Random? Does it make 450bhp?
Old Feb 29, 2008 | 04:23 PM
Jasesapphy's Avatar
Jasesapphy
Hmmm, deffo want roller bearing core (dont want lag as my lover Dan as mentioned), but really would be stuck on turbo, i just dont fancy GT series, my theory has always been smallest turbo possible to achieve the power you want.
im not chasing number so 430 in all reality would be cool, but it must be drivable and pin you, like a car to have plenty of torque.
im cllecting parts this year to do it next winter, but want to get it right
Old Feb 29, 2008 | 04:28 PM
NEIL A's Avatar
NEIL A
Its built to a similar spec to Rapidcossie's engine with the look to go 500+ with a roller bearing T4 later. I dont go for all the low comp crap off boost stuuf, its all down to what the tuner knows and works with best.
Old Feb 29, 2008 | 04:31 PM
rapidcossie's Avatar
rapidcossie
I just drove a saf with a t34/48 , standard comp, cams etc etc for over 100 miles and it felt pretty similar to mine.
Probably more responsive and slight in gear but nothing major really considering mines has all the big lag parts
Old Feb 29, 2008 | 04:32 PM
rapidcossie
Dan the comp ratio is so low so that the mapper can have full ign adv at any point n the rev range.
This has many advantages but not to many disadvantages.
Old Mar 1, 2008 | 08:00 AM
Dan's Avatar
Dan
Cool, nice one Euan!
D47 is a fucking cool car isn't it! Gutted Lee got rid of it tbh!
Old Mar 1, 2008 | 08:22 PM
Jasesapphy's Avatar
Jasesapphy
back up for night crew
Old Mar 1, 2008 | 08:25 PM
Jasesapphy's Avatar
Jasesapphy
need turbo advice and help i think
Old Mar 1, 2008 | 09:36 PM
Gary Osborne's Avatar
Gary Osborne
Thumbs up
not sure if it helps but my car is nearly ready for the road and i have a standard engine with a harvey spec ut 38 as advised by stu because he was doing the chip.
we reckon it should just make 400 and 380 with standard head and cams at 2 bar peak and 1.8 held.
might get to drive it soon so ill tell you what the harvey ut38 is like
Old Mar 1, 2008 | 10:01 PM
trevCOSS's Avatar
trevCOSS
whats wrong with what you have? go for 400 400 on the turbo you have, nice and responsive and doent run out of puf to fast, it seems to me that al thing s are a compromise with the yb and you will not always get the response of a t3 with the legs of a gt35 lol also although i agree that smallest turbo to get to the aim will give best response it may also cost most when you get bored i.e. upgrading all the time, if your loaded this is fine if your me this is not lol
Old Mar 1, 2008 | 10:02 PM
trevCOSS's Avatar
trevCOSS
same spec a B9KOS made 397bhp iirc, not sure about torque peak is over 2 bar though
Old Mar 1, 2008 | 10:06 PM
Gary Osborne
its actually a copy of his chip (easy money for stu lol)
i presume youve been in it so how fast is it?
mines 2wd and im expecting it to peel tyres all day when i want to.
Old Mar 1, 2008 | 10:10 PM
trevCOSS's Avatar
trevCOSS
yes i've been in it lol around various tracks driving lol, its ok to be honest, its not as quick as mine on a harvey 400 400 spec t35 but its not as expensive and not far off, the boost threshhold (spelling) is high but its a quick car and if you use the gears very drivable not the best but not to bad either also seems to be holding together nicely and rich and me are not gentle on it either.
Old Mar 1, 2008 | 10:16 PM
Gary Osborne
what head gasket is he using mate.
and how does it compare to your normal stage 3 cossie
thanks in advance
Old Mar 1, 2008 | 10:21 PM
trevCOSS's Avatar
trevCOSS
just yb0611? std group A, hes using, normal stg 3 his was faster than mine at normal stg 3 by a large amount yes it was, but to be honest its hard to remember exactly how much a fair bit iirc, dont fear though its a quick car, unfortunately, or fortunately the company we keep here on pf 400bhp is not much lol but out on the road its a quick car
Old Mar 1, 2008 | 10:48 PM
Gary Osborne
to be honest ive changed the spec on my engine three times before i even ran it in....
but all i want is to have a good summer in it and to build a 200 block 500 450 motor over this winter ( obviously to keep up with pf fashion lol)
fookin cars
Old Mar 2, 2008 | 06:10 AM
Jasesapphy's Avatar
Jasesapphy
what is Harveys spec for 400/400
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Mark_
40
Oct 2, 2015 04:40 PM
