brake calipers
Old Feb 28, 2008 | 07:05 PM
g1234's Avatar
g1234
Default brake calipers
what is difference in s2 and s1 calipers why dont s2 disks fit on a s1 with calipers
Old Feb 29, 2008 | 10:18 AM
JesseT's Avatar
JesseT
S2 discs are 20mm bigger and the calipers mount further out for this. Sure you can fit the s2 stuff to a S1 but you need to fit both the discs and calipers.
Old Feb 29, 2008 | 05:36 PM
xrmalin's Avatar
xrmalin
series 1 brakes are the same as the mk4 xr3i so the calipers off a series 2 will bolt straight up.
Old Feb 29, 2008 | 06:46 PM
NUTS RuS's Avatar
NUTS RuS
54mm piston and 60mm piston
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
