cossie sensor kit?
Old Feb 28, 2008 | 01:13 PM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
Default cossie sensor kit?
got a full engine bay sensor kit to hopefully cure my problems, are these easy enough to fit? especially phase sensor (does dizzy have to be removed completely?) and crank sensor?
cheeRS
Old Feb 28, 2008 | 02:00 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
only the dizzy cap needs to come off. You need to make sure you gap the phase sensor correctly and the crank sensor. Not sure of the gap you need. someone on here will know or a quick phone call to a tuner.
Quite an easy job though
Old Feb 28, 2008 | 03:19 PM
Zetec_mk4_XR3i
cheers dude - anyone know?
Old Feb 28, 2008 | 05:20 PM
I think the gap is about 0.25mm (but i could be wrong) make sure the wire to the phase sensor is plugged in the right way round cause if not the car wont start.
Old Feb 29, 2008 | 11:23 AM
Phase sensor gap is 0.2mm to 0.3mm.
The wire is correctly on when the top wire from the sensor goes to the nearest pin on the through connector in the dizzy body, you MAY have to gently bend the base of the phase sensor so that is is PERFECTLY parralell to the LOBE.
The cranks sensor is easy and gap is 0.6mm to 1.0mm, though they wil still work way outside this range.
CAUTION when setting crank sensor gap, check on ALL lugs, as if you set on a low lug(may be chipped/worn) then when a high lug(unworn) comes round it could clout it!!
jonfoc
16
Sep 11, 2018 05:35 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
mike elsome
Sep 14, 2015 04:08 PM
Si B
Sep 12, 2015 06:49 AM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
