twin intercoolers?
Old Feb 28, 2008 | 10:00 AM
Wazzzer's Avatar
Wazzzer
Default twin intercoolers?
Just looking at alternatives to an FMIC for my Golf and I've found some info on a twin intercooler setup similar to the Audi TT and S3s
Would this be as good or will it just create more lag?
any views?
Old Feb 28, 2008 | 10:17 AM
lead_foot's Avatar
lead_foot
is awesome
There is likely to be more of a pressure drop using two smaller intercoolers over just using one big FMIC.
Old Feb 28, 2008 | 10:19 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
in had a twin setup on my rst with 2 standard ic's and it worked a treat!
Old Feb 28, 2008 | 11:05 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Those 'Twin' Intercoolers you refer to are exactly the same concept as 'Twin-Pass' Intercoolers, like the GRS RST cooler, which I am using and have been using for ages. As far as I remember, they have an external 'elbow' to join the top and bottom cores, as oppose to an 'end-tank'.
It's a good idea and will work IMO.
Old Feb 28, 2008 | 11:10 AM
bud-weis's Avatar
bud-weis
Football Cwazy
I have these on my Leon Cupra R....there is no lag to speak of by using them!
There is a long solid pipe that joins them together running across the front of the car, behind the rad.
Old Feb 28, 2008 | 11:25 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Essentially its not going to be significantly different to if the two were just joined together into one longer one.
Will work fine.
Old Feb 28, 2008 | 12:52 PM
Mr.T's Avatar
Mr.T
you mean something like this?
Old Feb 28, 2008 | 04:25 PM
Wazzzer's Avatar
Wazzzer
the one I'm looking at puts another intercooler in the passenger side wheel arch mirroring the one I have as standard. As bud-weis says they are linked by a pipe running behind the rad. In my case I would also have to change the inlet manifold for one that has the throttle body on the other side, but this is included I think. If not I can get the inlet off a TT.
Cheers for the replies, I'll keep my eye on this
Old Feb 28, 2008 | 05:47 PM
Red16's Avatar
Red16
no reason why it shouldnt work... seems to do the job nicely on the Dahlback Racing Golf
and that car certainly aint shy
Old Feb 29, 2008 | 01:38 PM
bud-weis's Avatar
bud-weis
Football Cwazy
Personally i would search for someone breaking a Leon Cupra R, and just have all the bits you need off it.
I think the intercooler you already have will be almost identical to the one in the drivers side of the Leon/TT/S3...
Nov 1, 2015 06:53 PM
sridgett
Oct 1, 2015 07:30 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
Fudgey
21
Sep 30, 2015 06:19 PM
