Mondeo Central Locking
Old Feb 27, 2008 | 07:14 PM
Tels's Avatar
Tels
Default Mondeo Central Locking
Has anyone had experience with a Mondeo central locking system with a mind of it's own?
My Y reg 2000 ghia will occasionally unlock itself again whilst driving along and even on occasion lock all doors as well. Has been known to do this whilst stationary too.
It also occasionally loses the timer on the internal light after you get in. You know the one that supposed to stay on for x seconds or until the ignition is turned on.
I changed the key fob battery but am baffled.
Where is the control box?
Any other people experienced this?
Any clues?
Tels
Old Nov 16, 2009 | 11:03 PM
lanstoned's Avatar
lanstoned
StoneD
Hi Tels,
I have the exactly the same problem with a Y reg Mondeo Ghia estate!
Mine also has recharging trouble and frequently has to be hooked up to a battery charger or it won't start after beign idle for a day or 2.
Did you find a satisfactory solution for central locking problems and have you had similar recharging issues?
Old Nov 17, 2009 | 04:29 PM
Originally Posted by lanstoned
Hi Tels,
Few basic things to check for battery going flat, is battery ok, is the alternator charging ok, I think they are ecu controlled on these, but they can and do suffer from leaky diodes(one way electrical valves)so that the battery actually gets discharged by being connected to the alternator if these are duff.
I would get the charge rate and battery tested first, if the battery tests ok disconnect it and see if this solves the problem when you reconnect it to drive.
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
rsguy
44
Sep 29, 2015 03:29 PM
The Enigma
Sep 29, 2015 10:31 AM
