Petrol Cap getting stiff
Old Feb 27, 2008 | 06:27 PM
smerth54's Avatar
smerth54
Default Petrol Cap getting stiff
ok so my petrol cap is getting really stiff is this a common fault or is there something wrong any ideas as I have been standing in the petrol station for like 10 minutes before trying to get the cap open
Please help me
Old Feb 27, 2008 | 07:22 PM
Luca's Avatar
Luca
Lukesville
I had this few years ago eventually the lock spun in the palstic and i was foooked.
hAD to drill the lock out to get it off.
I would head to the scrappy and get a new one ASAP.. Try lubing the lock you have see if that frees it up
Old Feb 27, 2008 | 07:54 PM
Chris69's Avatar
Chris69
wd40 is your friend mate- soak it in and work it into the mechanism, should do the trick.
Old Feb 27, 2008 | 08:02 PM
frsjon's Avatar
frsjon
very common....best thing to do is take the e-clip off the back,strip it all down and lubricate everything....snapping the key in it when your at the petrol station with no petrol is not funny....
Old Feb 27, 2008 | 08:18 PM
Luca's Avatar
Luca
Lukesville
Sounds funny though
Old Feb 27, 2008 | 11:46 PM
smerth54's Avatar
smerth54
i have tried spraying wd40 through the lock but that didn't seem 2 work but i will try stripping it down and lubing it up see if that helps if not ill have 2 buy a new one and re spray it.
thanks for the help
Old Feb 28, 2008 | 04:01 PM
smerth54's Avatar
smerth54
one question is it hard 2 strip down the petrol cap i don't wanna do it then find i cant get i back together and have people steeling my petrol till i can get a new cap?
Old Feb 28, 2008 | 04:46 PM
smerth54's Avatar
smerth54
k i have put some lude in the petrol cap and lock and it seems a bit better will see if it holds later when i get petrol if not ill have 2 get a new barrel
Old Feb 28, 2008 | 08:16 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
I had the same problem on my Escort, you need to REALLY soak it in oil, and I mean get some 3in1 and soak it in a container. Works a treat.
Old Mar 7, 2008 | 10:01 AM
beef2001's Avatar
beef2001
Boost it
Yeh i had the same prob its a nightmare isnt it, I sprayed it with wd40 once a week for 3 weeks and now its sorted new caps aint much dosh though
timsrs
Nov 13, 2018 11:48 AM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
20/20 vision
Sep 28, 2015 03:03 PM
Brickhouse
Sep 21, 2015 11:00 AM
