cvh valves
ohh forgot to mention dont just change the cam or it'll eat the new lifters to bits in a few thousand miles....use the ones from the rst cam if possible.
Just as a precaution as i've seen the cam chew up on a few rsts in the past by changing just the listers or just the cam.
Dan
Dan
Skint Passionford User
Right, so can I leave the std valves in then and just use the rst cam and lifters?
I've got a piper N/A cvh cam kit I can get really cheap if I want it, would that work well in a turbo'ed engine?
Whats the difference between the cam pulleys?
Well what year car/lump did the mfi head come from? If its a pre Dplater then you need to swap the exhaust valves over.
I was unaware of the D plate cutoff though...I htought it was all mfi heads had sod filled valves..my bad.
Dan
Dan
Its an E plate MFi head, and the EFi head i've bought was from a late orion ghia so I'll presume i'm Ok with valves (most prob buy new ones anyway for peace of mind tbh),
I am interested to find out what the differences are between the MFi RST cam and the EFi Orion 1600E cam though? and the Pulley difference if any?
Ta for the help so far btw
if your buying valves buy sodium ones, they cool better....as for the cam and pulley differences I havent got the foggyest m8...cam profiles are probably better suited to turbo application and not n/a
Thats good cam. timing is different and that's done by using different pulleys... RST pulley should have KA on it. But in reality you will feel nothing in comparition to RST MFI cam. But I was told that EFI one has better profile, so use that one for few extra BHP.
I liked the EFI cam a lot in comparison to the std. cam.
The RST pulley has 4 degrees of retardation.
The sodium valves are way overrated. There's nothing wrong with the standard valves.
Here's the efi inlet vales on the left and mfi on the right.
All the the escort/orion 1.6cvh cam shafts are the same profile (and have the same part no. at Ford), but the EFi cam shaft is made from a harder material and so doesnt wear as fast!
I think any new cam shaft bought from ford now will be made of the harder material, unless they have a random old cam lying around from pre 1989!
Thats right these days they list only one cam.
But I assure you they where not the same back then... I have few of them lying around and I compared them..they ar not the same.
mk3ste
Oct 17, 2021 10:09 AM
