s2 fueling prob
Old Feb 27, 2008 | 08:36 AM
lewis_lisa's Avatar
lewis_lisa
Red face s2 fueling prob
hi folks my s2 has just had a new bottom end put in and was running fine on the first few start ups. over the last few weeks it has been taking longer to start each time and just coughing? when its been starting ive had to hold the revs at about 2000rpm to keep it running if i let off it dies. it also has started running on 3cylenders when cold and the afr computer is readin lean until warm.
the other week when it warmed up i took it up my street and when it dumped it didnt sound rite, i tried it again and the engine cut out now it only caughs and wont start.
ive noticed the fuel hose from filter has been crimped a bit and has a small hole in it so it is leaking. under the bonnet reaks of fuel i doctored the hole up but it still wont start.
my m8 recons its the copper washers on metering head that will need changed as they have been off and on a few times and as the hose is sqaushed a bit it will need changed
cheers for any help guys.
Old Feb 28, 2008 | 04:52 AM
turboloon's Avatar
turboloon
wot sort of plugs and leads you running ...?i had similar problems i had magnegor plug leads and a mechnaic friend told me to get shot of them i was abit like holy shit these are 'spoosed to be good leads any how i changed the plugs and leads and it purrs like a kitten now...
Old Feb 28, 2008 | 08:30 AM
lewis_lisa's Avatar
lewis_lisa
m8 i have magnecore leads too. think my plugs are just ford 1s.
the car ran fine before which is strange?
timsrs
Nov 13, 2018 11:48 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
