Saph Wiring
Me Cossie Runs Atlast!!!!
On my G -reg saph there is an ECU in the left and right footwells behind each kick panel. On my new body shell the left hand one is mounted behind the glovebox on a bracket. and i cant work out how the right hand one mounts? Any ideas why the difference?
James
James
If you are fitting a 2wd loom into a non cossie base car a little wiring, if fittingh into a cossie car to start with it all just plugs in, at variuous points inside the car, then the loom obviously on the engine.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
