can you get adjustable rear beams
Old Feb 25, 2008 | 07:28 PM
whoopty's Avatar
whoopty
Default can you get adjustable rear beams
can you get adjustable rear beams to adjust rear toe when needed if so where sells them?
Old Feb 26, 2008 | 12:17 PM
It is not that difficult to make the rear arms adjustable for TOE and CAMBER.
Old Feb 26, 2008 | 04:59 PM
rinus_2005's Avatar
rinus_2005
you've got me reading... in situ? or you mean by making up shims?
Old Feb 27, 2008 | 05:46 AM
IN situ, with a few spanners, just copy how they did it on the rally cars.
Basically a threaded rod end in each location point of the arm, the inner one points forwards, so that adjusts your toe(as other point is fixed) the outer joint points upwards so that adjusts the camber.
They welded a tube in each position that the rod end threaded shaft bit passed through.
I have got some piccies somewhere, I may have got the inner/outer mixed up as on the phone at the mo!!
Old Mar 29, 2008 | 07:40 AM
Vic's Avatar
Vic
Hey mate,
any luck with those pics?
Old Mar 29, 2008 | 09:51 AM
LINCOLN's Avatar
LINCOLN
Vic - this is my ZOO beam.
Can get it on a pallet next week.
Old Mar 29, 2008 | 04:34 PM
cosworth.hu
Look under "GALLERY"
sorry tried to get link up but shitty tiscali is even more crap than normal today.
Old Mar 30, 2008 | 10:06 AM
Vic's Avatar
Vic
cant see a pic Lincoln.. must be pretty light! lol
Old Mar 30, 2008 | 10:09 AM
Vic's Avatar
Vic
cosworth.hu
thanks mate.. never seen that site b4..
cheers
Old Mar 30, 2008 | 06:38 PM
Me portuguese mate told me about it, good isn't it ?
jessie_rs
62
Aug 6, 2019 09:27 PM
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
