escort mk5 rev counter
Old Feb 24, 2008 | 09:25 PM
trossnova's Avatar
trossnova
Default escort mk5 rev counter
just changed my dials in my escort for a set with a rev counter just wondered how i wire it up so it works?
Old Feb 24, 2008 | 09:33 PM
zetecapri's Avatar
zetecapri
2.0 16v Turbo
what engine you got? plugged one into my 1.4 and it worked, wiring was there for it.
Old Feb 24, 2008 | 09:41 PM
trossnova's Avatar
trossnova
its a 1.4 cvh mate wires looked like they where their at the dash end but not sure where it goes on the engine end?
Old Feb 25, 2008 | 09:54 AM
trossnova's Avatar
trossnova
bump! so where is the wire located at the engine end?
Old Feb 26, 2008 | 08:35 AM
trossnova's Avatar
trossnova
bump
Old Feb 29, 2008 | 06:37 PM
scortpower's Avatar
scortpower
you should just plug it in and it should work , mine did! mine was a 1.4 cvh mk5 well used to be a 1.4
Old Mar 1, 2008 | 05:56 AM
As said no doubt all the same loom so will already be there, just plug and play.
Old Mar 1, 2008 | 07:08 AM
rapidonion's Avatar
rapidonion
is it carb or sfi you will have a green wire on you loom plug on the bulk head this then would go to a suppressor on the nearside wing just near the strut top out of the suppressor comes a red and green wire this is connected to the eidis and thus runs your tacho or you could of course splice into the wire were it come out of the loom plug on the clocks (only one green wire so you cant miss it)run a fresh wire to the coil pack and splice it to the red and green wire this will give you a good voltage signal to run your tacho make sure all connections are properly soldered though.
whizzisat114
Sep 1, 2015 02:19 PM
cozzy jeff
Aug 31, 2015 04:14 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
cozzy jeff
Aug 14, 2015 05:46 PM
stevierob
Aug 11, 2015 09:08 PM
