Brake bleedin problem
Hey guys im havin a problem blledin ma brakes on ma 2wd saph cossy i change all the pipes at the reat and the one pipe from front to rear, cant seem to bleed at all abs light is on would thats be causein a problem iv disconnectd the front to rear pipe and there is fluid dripping out the pipe but when i press the brake pedal it stops and the pedal is solid no travel in it at all ????
