Starter motor problems
Old Feb 23, 2008 | 06:10 PM
blk-Mk5-zs's Avatar
blk-Mk5-zs
Default Starter motor problems
my starter motor from my mk2 xr2 only likes to turn the engine over when its cold! if the car has been for a 10 mile drive, switch off, when i turn the key the engine turns over really slow. wait half an hour, it turns it properly?!
anyone heard of this problem before?
Thanks
Old Feb 23, 2008 | 11:22 PM
tonyrally's Avatar
tonyrally
passionford god
hi there yes a friend of mine had this problem changed the starter a few times but didnt make any diference in the end it turn out to be the high tension wire to the starter. he changed that an it was spot on thanks tony
Old Feb 23, 2008 | 11:27 PM
zetecapri's Avatar
zetecapri
2.0 16v Turbo
is the starter at the front of the engine? try moving the wires far away from the exhaust as you can.
Old Feb 24, 2008 | 04:40 PM
Also a sign of sticky or worn brushes.
Old Feb 24, 2008 | 08:55 PM
blk-Mk5-zs's Avatar
blk-Mk5-zs
so change the main power cable to the starter see if that makes a difference? where did he get the cable from?
i thought it could be the wires getting hot and creating a resistance in the cable, any ideas how i can keep the temps of the cable down? insulation or something?
if thats not the cause ill try the brushes.
thanks
cossie362
Oct 11, 2015 03:53 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
marky_g
Sep 12, 2015 04:26 PM
