cossie loom
Old Feb 23, 2008 | 05:14 PM
wimble's Avatar
wimble
Default cossie loom
neer the ecu plug there are two small plugs
one with 5 connectins on it (2 not used)
and one with three connections on it (two black wires and a brown)whot is this for
and why would some one connect the brown with one of the blacks together
Old Feb 23, 2008 | 05:51 PM
wimble's Avatar
wimble
i now have the two looms in front of me with a wireing diagram
and one 2wd loom has a purple plug for a relay that isnt used
and the outher loom dosent
Old Feb 23, 2008 | 07:14 PM
velocity's Avatar
velocity
Smile
the one with the five holes is a diagnostic port.it gives error codes in the form of flashing led on a unit that plugs in to it
the other is an ignition timming adjustment, by bridging the brown wire with one or both of the black wires retards the ignition by set amounts.
someone could have done this to stop pinking with crap fuel
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
muz
Sep 30, 2015 08:29 AM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
