eec iv ecu
Old Feb 21, 2008 | 12:16 PM
orion turbo's Avatar
orion turbo
Default eec iv ecu
i mate off mine has a 1990 xr3i which i have fitted a 2.0 throttle body and xr3i 130 spec injectors to i was just wondering as there both eec iv managment could i put a 130 spec ecu int the cvh for added fueling
Old Feb 21, 2008 | 12:34 PM
Maki's Avatar
Maki
I'd say you are doing it wrong. 1.8 injectors are to big for your 1.6 anyway. 8v head doesn't flow that much air as 16v would and your mod with 2.0 throttle body will give you nothing. 1.6 CVH EFI throttle body is big enough even for 2.1 ZVH so why change one? I'd say you are doing to much mix match here. Wise thing would be to get 1.8 zetec and put what you have on it along with 130 BHP cams...then there would be sense.
M.
Old Feb 21, 2008 | 05:53 PM
Mr.T's Avatar
Mr.T
M.
Why do you think he has a 1.6?
Old Feb 21, 2008 | 06:00 PM
MarkN's Avatar
MarkN
Because they didn't make a 16v XR3i in 1990 - it would be a 1990 Mk4 CVH EFi. They didn't put Zetecs in Mk5s until early 1992.
It probably won't take kindly to having the injectors changed because the fueling will be out.
Old Feb 22, 2008 | 01:04 PM
Maki's Avatar
Maki
He mentioned CVH.... there where NO 1.8 CVH in escorts.
Old Feb 22, 2008 | 07:34 PM
Mr.T's Avatar
Mr.T
Talking
Yeah right. Didn't see that
Old Feb 23, 2008 | 10:52 AM
SafeChav's Avatar
SafeChav
If the engine in question is a CVH - I'd be quite interested to know how you fitted 130 spec injectors to a CVH inlet, being as they are completely different fitments
Old Feb 23, 2008 | 07:59 PM
Mr.T's Avatar
Mr.T
Talking
YOu always can try it and you can even try to place the 2.0 ecu on it. But im pretty sure it wont work
Old Feb 28, 2008 | 01:09 PM
orion turbo
the injectors are near the same as the 90 spec 3i's are efi they actually fit straight in
and with the 2.0 throttle body on there it made a huge noticable difference
Old Mar 3, 2008 | 01:22 PM
SafeChav's Avatar
SafeChav
yes i know that 90 spec 3i's are EFI. The injectors fitted to a 130bhp (zetec!!!!!!) engine aren't even close to being the same fitment.
I would love to see a picture of this.....
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mile30
69
May 13, 2017 08:44 PM
griffo69
Oct 4, 2015 11:58 AM
STAFFY OWNER
18
Sep 21, 2015 02:50 PM
DixieTheKid
Sep 14, 2015 09:04 PM
