2WD stainless steel manifold
Old Feb 21, 2008 | 11:22 AM
florent78's Avatar
florent78
Default 2WD stainless steel manifold
I do some search and fine nothing for this subject
is it true that when you use a stainless steel manifold you can reduce from 500 rpm turo lag
is it tro
some of you do some dyno before and after ???
thanks
Old Feb 21, 2008 | 01:45 PM
The material used is not going to effect the lag, the design will though.
Old Feb 21, 2008 | 02:45 PM
AndyPen's Avatar
AndyPen
Most of the cheaper ones simply don't fit - ask Thanasis for a pic of what he had to do to his. He has done a good job but it took a lot of careful work!
Old Feb 22, 2008 | 12:22 PM
florent78's Avatar
florent78
ok
and just a good design can raise from 500 rpm the start of the turbo ???
it's theorical or some member see it with dyno ??
Old Feb 22, 2008 | 12:35 PM
rapidcossie's Avatar
rapidcossie
Im having my manifold coated to see if that will effect things, so will report back
Old Feb 22, 2008 | 10:22 PM
florent78's Avatar
florent78
perfect
thanks
Old Feb 23, 2008 | 07:34 AM
The manifold won't affect it hardly at all, a de shroud of the head will though.
My T34 makes 142lbft at 1500rpm, 330lbft at 2200rpm, and holds it all the way to 6300rpm, still at 330lbft.
jessie_rs
62
Aug 6, 2019 09:27 PM
mark r
Sep 29, 2015 07:27 PM
little bram
Sep 27, 2015 07:45 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
Adam Graham
Sep 6, 2015 06:04 AM
