Can I alter the date of an original document?
Old Feb 20, 2008 | 07:04 PM
Gez500's Avatar
Gez500
Default Can I alter the date of an original document?
I have several original documents which I need to scan and copy, but need the date to be different from the original.
We are in the process of applying for migration visas, I had to do a skills assessment first which involved loads of time sorting old employment references and other related paperwork. The second stage is the visa application which requires all the same references but dated within a month of sending them. To save the hassle of going round and getting them sent out with a different date, I want to alter them myself.
Can it be done? Any help would be much appreciated.
Cheers, Gez
Old Feb 20, 2008 | 07:21 PM
Benni's Avatar
Benni
Ban[B][/B]ned
I've changed my brothers GSCE results, from fails to B's and A's and then put my name over it before today. Not to mention adding another 6 exams.
Anything is possible?
Old Feb 20, 2008 | 07:39 PM
nickscunny's Avatar
nickscunny
you fraud you.....
Old Feb 21, 2008 | 12:09 AM
Gez500's Avatar
Gez500
Benni, how did you do it?
Gez
Benni's Avatar
Benni
Ban[B][/B]ned
Gez
Adobe Photoshop. I used text within the document to overrite text. Use a shitty scanner, fax machine and you will fail instantly.
Old Feb 21, 2008 | 12:12 AM
Gez500's Avatar
Gez500
Thanks, will give it a go
Old Feb 21, 2008 | 12:20 AM
Benni's Avatar
Benni
Ban[B][/B]ned
BTT! Because I just added more.
Old Feb 22, 2008 | 04:03 PM
Gez500's Avatar
Gez500
Which version of Photoshop do I need to get?
Old Feb 28, 2008 | 11:58 AM
St3V3_C's Avatar
St3V3_C
If they find out you will get fucked.
Do it properly.
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Oranoco
12
Oct 2, 2015 02:18 PM
Steve Escos
Oct 1, 2015 06:57 AM
