Uprated Fuel Pump??
Hello all
Does anyone else run a ST Escort with GG 305 conversion with standard fuel pump. Standard injectors, SS exhaust , no cat..K&N...
Car goes fine, just wonderered if it would go better with a Higher pump fitted.
any thoughts
any thoughts
as long as the pump isnt tired, is recieving a good 12v supply and from that it should be flowing at the correct rate then there is no reason why you should have any concern.
Failing that, an 003 pump is a direct upgrade replacement and will ensure you have sufficient fuel supply.
oh, and i have one of those for sale
on the gg305 conversion, how well is well
im thinking about gettn this done, but dont want to spend the money7 and then find it boring and change to big turbo
rather just change to bt now
greetz
fudaga
its up for sale at £60, was on my car a litle over a year, so probably covered about 4000 miles (ish).
ill gladly post it anywhere you wish mate, as long as postage is covered.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
