How would you go with this Erst, ambers etc or clears
This is the erst I bought recently, it needs a few of the plastics replacing, a headliner, and a tailgate, as well as a few touch ups and the front bumper repairing.
Having said that, I'm using it every day for work and it starts first time, which I think is good considering I've been setting off about 6.45 and it's been -5 degrees in the night.
I'm getting the bits painted in the next couple of weeks hopefully and the bumper done ( will still be after a tailgate tho) but I don't know wether to keep the clear indicators and repeaters, or go to ambers.
Also, the front is a bit lower than the rear, if i go ambers i would probably lift the front to match the rear, but if i go clears i might lower the back to match the front, i can't make up my mind, what you guys think?
Also don't know wether to put black stripe into bumpers
[img]
[/img]
[img]
[/img]
Thought so, ambers seems to be the current done thing, what do you think for the front, standard springs or lesser-lowered lowering springs? also what would this look like vs the rear?
If I'm having ambers i would put the black stripe in and keep the spots
Mc5506
Oct 5, 2015 09:57 PM
