ECU's
Old Feb 19, 2008 | 03:21 PM
JohnL's Avatar
JohnL
Default ECU's
I have 2 ecu's, one has a babyboard with collins stg1 chip, the other just has stg1 chip no babyboard.
the one with the babyboard seems to have died, should i not be able to start the car with the other ecu??
also is it possible to swap the baby board and work?
thanks
john
Old Feb 19, 2008 | 09:17 PM
JohnL's Avatar
JohnL
anyone??
Old Feb 19, 2008 | 09:28 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
check you have spark and fuel before starting it and dont go boosting about....get it to a tuners and make sure it's not running lean on boost then if its good to go then your lucky.
Dan
Old Feb 19, 2008 | 09:44 PM
JohnL's Avatar
JohnL
so it should work just simply swapping 1 stage1 ecu for another?
Old Feb 20, 2008 | 04:31 AM
stevecossy's Avatar
stevecossy
The collins baby board replaces the orig 1, so if the other ecu you talk about has the stg 1 chip plugged into an orig baby board then you can just swap the ecu and see if she fires up.
If ya still av a prob then as above its time to check other things.
Good luck
Old Feb 20, 2008 | 08:36 AM
JohnL's Avatar
JohnL
have taken a picture:
on the left is my original with collins chip stage1 1993 escos
on the right, a p8 from a 1992 escos with stage1 but no babyboard?
should it not still run?
Old Feb 20, 2008 | 09:37 AM
grcossie's Avatar
grcossie
It should start whit the other ecu yes. You can also swap over baybyboard, whit the chip who stands in it. Some chips, need babyboard other dosen`t work whit it. It is not original, whit board at all.
Old Feb 20, 2008 | 09:41 AM
JohnL's Avatar
JohnL
Cheers mate, i meant the original one i had. am off to collins now to get them both looked at...
Old Feb 20, 2008 | 09:59 AM
grcossie's Avatar
grcossie
You get it sort out then. Just great to help.
Regards Geir Rune
Old Feb 20, 2008 | 10:19 AM
stevecossy's Avatar
stevecossy
yeah as above sorry i did not know it was p8 ecu, thought ya talk about L8
Collins should help ya out as always been great with me.
Good luck
Cheers steve
Old Feb 20, 2008 | 07:03 PM
Stu @ M Developments's Avatar
PassionFords Creator
Both will interchange as long as you dont try and swop the chips themselves.
IE:
You CAN put the chip and board in either P8.
You CAN put the boardless chip into any P8 with no board in.
Old Feb 20, 2008 | 07:09 PM
JohnL's Avatar
JohnL
cheers stu
looks like i should be looking at other possible faults then like loom
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
