Max t38 boost
Old Feb 18, 2008 | 07:21 AM
warrenja1's Avatar
warrenja1
Default Max t38 boost
Whats the maximum boost that can be expected from a T38 and whats the max that it can be run at?
Was working on a cossie today with a t38 but I cant get the boost pressure above 20psi even with the actuator pipe disconnected.
Theres no air leaks, and the actuator is definetley holding shut.
Relevant engine spec is;
turbo technics t38
92.5mm bore
7.2:1 CR
BD14 cams
swedish inlet manifold
rs500 intercooler
2wd exhaust manifold
Anyone got any ideas to why i cant get any more boost pressure.
Is there any chance that the wastgate flap inside the turbo isnt closing fully?
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
