service
Old Feb 17, 2008 | 07:39 PM
RS LOZWORTH's Avatar
RS LOZWORTH
Default service
i plan on carrying out a service on my 2wd saff cossie, wots stuff do i need.... im not doing the cam belt just stuff like oil, pads etc,
thanks
Old Feb 17, 2008 | 07:41 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Oil / filter / plugs / leads / air filter (if not a cone) are the main ones. Check the discs and pads and see what they're like before you go buying stuff you don't need.
Old Feb 17, 2008 | 07:44 PM
RS LOZWORTH
what grade oil shall i use, im currently using 10/40
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
When was your coolant and brake fluid last changed?
Old Feb 17, 2008 | 07:45 PM
RS LOZWORTH
coolant last week- but i only used 1ltr, and brake fluid bout 2 months ago
Old Feb 17, 2008 | 07:49 PM
LHD220Turbo's Avatar
LHD220Turbo
oil - massive topic
read these
https://passionford.com/forum/viewto...highlight=%2Ao il
Old Feb 17, 2008 | 07:51 PM
RS LOZWORTH
Originally Posted by LHD220Turbo
well thats intresting- what on earth shall i use
Old Feb 17, 2008 | 07:55 PM
Dangerous Malcolm..
What's it running like on the 10/40.
LHD220Turbo
pro s silkolene i would go for
Old Feb 17, 2008 | 07:58 PM
ECOS95's Avatar
ECOS95
As above.
Old Feb 17, 2008 | 08:01 PM
RS LOZWORTH
it seems fine, but i dont really know the pro's and cons of oil, i say its fine but it maybe better with different oil i just dont know
Old Feb 17, 2008 | 08:03 PM
Dangerous Malcolm..
It's just a 10/40 might be a bit thin depending on it's state of tune. Is it a bit tappety after a hard run?
Old Feb 17, 2008 | 08:05 PM
RS LOZWORTH
to be honest id say its more tappety when its colld and before a gud run and its 332bhp
Old Feb 17, 2008 | 08:16 PM
Dangerous Malcolm..
If it's ok when warm then stick to a 40, why not try a 5W/40 instead.
Old Feb 17, 2008 | 08:19 PM
RS LOZWORTH
[quote="Leeeroy"]If it's ok when warm then stick to a 40, why not try a 5W/40 instead. [/quote
whats the 5 mean? is it thicker?
Old Feb 17, 2008 | 08:23 PM
Dangerous Malcolm..
Thinner when cold. Maybe the 10 you're currently using is a tad thick when cold.
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Fudgey
21
Sep 30, 2015 06:19 PM
stevecfrst1
Sep 30, 2015 05:18 AM
