Rust treatment?
Originally Posted by Billy_RST
I mean the jelly stuff ive seen used.
I dont mean like proper rust, im talking surface stuff
Yes i know and the car is going to a bodyshop at the end of the year for work, but for now i just wanted to do something with it.
Also, you got a PM mate
got to cut bad rot out. but surace rust can be removed if only surface with aflap disc. You remove a bit of metal with it but only minimal if it is only surface rust. If it is penetrating thr metal then ylu can always spot blast the area!
Cheers, decent anwser to question.
