2wd and 4wd fly wheels are they the same??
Feb 15, 2008 | 08:22 PM
Feb 15, 2008 | 08:23 PM
Feb 15, 2008 | 08:27 PM
Whats the diffrence, could be the reason my clutch collapsed?
The 4x4 is heavier if i remember correct
you can use either in each car tho
Feb 15, 2008 | 08:33 PM
Quote:
They are all interchangable i.e. the clutch sits in the same place but weights differ by a large margin.
Feb 15, 2008 | 08:34 PM
So ok using a 4x4 fly wheel in a 2wd or is it best to swap it for a 2wd one
Feb 15, 2008 | 08:39 PM
Quote:
Depends which model 4x4, there are three 4x4 flywheels!! But 2wd is the best bet..
Feb 15, 2008 | 08:45 PM
Feb 16, 2008 | 06:32 AM
Hi,
2wd flywheel is 8,5 kg (18,8 lb)
4 wd flywheel is 11,5 kg (25,5 lb)
(if my conversion is right !!!!)
Regards
Claude
Feb 16, 2008 | 06:46 AM
So what is the logic of the heavier flywheel in the 4x4 out of interest?
JJ
Feb 16, 2008 | 06:54 AM
Does the heavier flywheel give more torque
Feb 16, 2008 | 07:01 AM
Sounds plausible I guess. I wondered if it was anything to do with the gear change becuase of the additional 'drag' caused by the 4x4 system effectively trying to slow the engine down on engagement (ie to reduce possibility of stall)?
JJ
Feb 16, 2008 | 07:44 AM
would be plausible, so a better torque figure could be achieved if used
Feb 16, 2008 | 07:56 AM
Hi,
Another reason, given by Ford, is heavier flywheel avoid gear box clatter, that it can exist with 4x4 MT75 gear box..
Regards.
Claude
Feb 16, 2008 | 12:06 PM
inertia
Feb 16, 2008 | 05:40 PM
Quote:
Originally Posted by WD Pro
inertia
spot on- gives a smother gear change as the revs wont dip as much but also take longer to spin up
mint_s2
Sep 2, 2015 08:58 AM
FlashRS
13
Aug 31, 2015 06:02 PM
RsS2daz
Aug 14, 2015 05:26 AM
lockie
Jul 31, 2015 10:03 PM
Old ford
Jul 31, 2015 06:50 AM
