wrc 8 injector plenum siamese style
Old Feb 15, 2008 | 07:44 AM
Mark Barber's Avatar
Mark Barber
Default wrc 8 injector plenum siamese style
hi folks im planning on using one of these has anyone else ever used one if so are they any good and will a p8 run all injectors ta ??
Old Feb 15, 2008 | 08:17 AM
Paul Eggleton's Avatar
Paul Eggleton
Is that not just a std RS500 inlet????
Old Feb 15, 2008 | 08:21 AM
Dan's Avatar
Dan
Did the RS500 inlet not have 4 injectors mounted on the front of them?
Old Feb 15, 2008 | 08:24 AM
Ryan's Avatar
Ryan
its a 8 injector runner with a 4x4 plenum cover on it.
Old Feb 15, 2008 | 08:27 AM
rscostalot's Avatar
rscostalot
not a 500 setup, as the 500 set up had 4 injectors on top "ie" same as 2/4wd then another 4 on the face of chamber. Siamese twin injector set up or "wrc" as commenly known.....
hope this helps...
Old Feb 15, 2008 | 08:30 AM
Dan's Avatar
Dan
Ryan that plenum cover looks identical to my 2wd mate? Were these the same aswell then?
Old Feb 15, 2008 | 08:32 AM
Ryan's Avatar
Ryan
then yours isnt a 2wd one.
4x4 plenum cover is a 1 peice item with a slightly better flowing eblow.
2wd is a 2 peice item, and the elbow is removable via 3 bolts.
Old Feb 15, 2008 | 10:11 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
No
I would just use bigger injectors than one of these manifolds.
Steve.
Old Feb 15, 2008 | 11:48 AM
Dan's Avatar
Dan
So on a 4x4 plenum the elbow is 'all inclusive'? Mine is definately a 2wd plenum as the elbow was removed when i sprayed it
Just the front of the one above and mine look the same where all the sensors go etc
Old Feb 15, 2008 | 11:52 AM
Deleted by Request's Avatar
Deleted by Request
Former Sponsor
..Yes i had same setup except i used the EEC4 plenum cover...apparently the best way of fuel delivery...I had no running issues at all and i beleive Mike R the resident bottom feeder stills uses it.
Old Feb 15, 2008 | 12:19 PM
GARETH T's Avatar
GARETH T
i personally would just buy 4 large injectors, and sell the inlet on ebay!
Old Feb 9, 2009 | 10:05 PM
cossyking's Avatar
cossyking
better using 8 then your not running big injectors wasting fuel when not needed
Old Feb 9, 2009 | 10:26 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
lol.
i run 4 big injectors and cruise at almost 40mpg...idle co of 0.50%
my advice to you is change tuners! yours seems stuck in the 80s
Old Feb 9, 2009 | 10:29 PM
polly_x's Avatar
polly_x
Why does using 4 large injectors mean your wasting fuel when not needed?
JTECH James
Passion for Fords!
Old Feb 10, 2009 | 02:55 AM
RS500/364's Avatar
RS500/364
Used the RS500 on P8 Super set up
(was thinking of selling the P8 Super ECU) and just doing the P8ECU 4 large set up with anti lag air 2 air and msn closeloop as soon as can be ased but not using on siamese but the RS500 set up so cant answer (the set you want to use )but 4 is fine and the spray patten / Mapping co can be done easier now days !
Would expect them to be fine and saves you a bit of cash to getting the RS500 8 inj set up
Old Feb 10, 2009 | 04:37 AM
SteveH's Avatar
SteveH
Almost a 12 month bump
We should have a leaderboard
Old Feb 10, 2009 | 08:07 AM
RS500/364's Avatar
RS500/364
Well the amount of time some builder take to do the engine its quite quick !!
mk3ste
Oct 17, 2021 10:09 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
timsrs
22
Sep 24, 2015 08:14 PM
