st170 to zvh
Bodybuilding
From: Cannot be identified by the information given.
can you use a st170 bottom end and convert it to a zvh ?
i would use the whole engine but i only got the block
ive heard the rods are longer than the normal zetec rod
Originally Posted by G2RSR
could i use normal zetec pistons on the st170 rods ?
do you know if the Piston Pin is a different size the the normal zetec rod
no what i mean is can i use after market low comp forged pistons for the zetec with the st170 rods
Andypandy260
Sep 23, 2015 10:28 PM
