Tramping?
Old Oct 16, 2004 | 11:49 PM
SPADGE's Avatar
SPADGE
Default Tramping?
What causes it and what cures it?
Cheers Spadge...
Old Oct 16, 2004 | 11:52 PM
Jim Galbally's Avatar
Jim Galbally
i been meaning to post the same thing for ages! lol
just to check, it tramping when the car "bounces" when wheelspinning?
mine does it a lot and its bloody irritating!
Old Oct 16, 2004 | 11:56 PM
RSrussell's Avatar
RSrussell
Jim i thought you'd be the best person to ask about tramping
Old Oct 16, 2004 | 11:58 PM
SPADGE's Avatar
SPADGE
Originally Posted by Jim Galbally
just to check, it tramping when the car "bounces" when wheelspinning?irritating!
Yep thats the one Jim!
Lol @ Rick
Old Oct 17, 2004 | 12:06 AM
RSrussell's Avatar
RSrussell
Its due to the rear end suspension setup and power applied, ain't it, or do you want more info
Old Oct 17, 2004 | 12:13 AM
Zetec Andy's Avatar
Zetec Andy
My mates new Audi A4 does that aswell
Old Oct 17, 2004 | 12:14 AM
SPADGE's Avatar
SPADGE
I know that much Rick
Was looking for a bit more info to be honest
Old Oct 17, 2004 | 12:16 AM
RSrussell's Avatar
RSrussell
I thought so. lol
I guess danny b, zoo should be able to explain.
Even Danny bogged now and again with his setup, so i don't think its totally banishable.
Old Oct 17, 2004 | 12:45 AM
Phil's Avatar
Phil
Jeebus
Tramping as I know it is when a leaf spring twists sideways under load and then springs back and so on.
Cured on the Ford works cars by use of anti-tramp bars..
..but seeing as Cos's don't use leaf springs it's completely irrelevant!
Old Oct 17, 2004 | 12:48 AM
SPADGE's Avatar
SPADGE
Its not irrelevent to me Phil as i am deffo getting the symptoms of tramping on my cossie under hard launching since i fitted the coil overs
Old Oct 17, 2004 | 12:50 AM
Phil's Avatar
Phil
Jeebus
What exactly is happening? Vibrations on hard launching?
Old Oct 17, 2004 | 12:54 AM
Deano's Avatar
Deano
Id say it was more THUD THUD THUD I remember mine doing that aswell
Old Oct 17, 2004 | 12:59 AM
SPADGE's Avatar
SPADGE
Yep a bit like that!
Old Oct 17, 2004 | 01:03 AM
nomad's Avatar
nomad
OMG
we used to go tramping, all you need is a 5 gallon container full of petrol, some woods and a good pair of quiet NIKES,. cheers nomad
ps some days we use to average 25 to the gallon
pps never heard them go THUD THUD THUD, more
"bejesus me ass is on fire"
Old Oct 17, 2004 | 01:13 AM
Billabong's Avatar
Billabong
Your springs are possibly too high a poundage.
Old Oct 17, 2004 | 01:18 AM
NUTS RuS's Avatar
NUTS RuS
As Bill ....
Softening the back end will help.
Old Oct 17, 2004 | 08:32 AM
POPEYE's Avatar
POPEYE
FAIRY CAKE
fpmsl,as jules and jim have said i was gonna post this aswell
mind you mine dont do it all the time,plus i only springs/shock with coil assitors
i put it down to the different road surfaces,ie to grippy
maybe now i have the back raised up i might try and run it without the assitors,but i dont really want it squatting to much and losing grip
Old Oct 17, 2004 | 08:44 AM
starturbo's Avatar
starturbo
I get a problem when I nail my rst2 hard.The gearlever appears to thump the underneath of the car.I know its not what you talkin about but its a horrendous noise.makes you back off.sounds like the gear linkages are gonna come through the floor.I wondered if a rubber mounting has worn out or is loose?
Old Oct 17, 2004 | 08:50 AM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
I had this problem a while ago. when i looked into it was told it was because the nose of the diff is lifting and as it lifts the wheels get fired on the ground because of the bouncing nose.
try changing your rear diff mount.
Daniel
Old Oct 17, 2004 | 09:02 AM
gazcos's Avatar
gazcos
As said above its probably a combination of too higher rear spring rates but mostly inadequate diff location
Old Oct 17, 2004 | 09:43 AM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
rear diff mount spadgeroo
Old Oct 17, 2004 | 09:44 AM
POPEYE's Avatar
POPEYE
FAIRY CAKE
and the cure would be?
Old Oct 17, 2004 | 09:51 AM
Matt's Avatar
Matt
a new relocated diff mount of course pops
ggr sell an "anti tramp" aka a fast road beam kit - GGR068 - Ł52.50
consists of a big plastic washers that you fit on the rear beam bushes to stop movement
Old Oct 17, 2004 | 09:54 AM
Dan@Rapid-Ford
just a new Ford diff mount would probably help.
Daniel
Old Oct 17, 2004 | 11:22 AM
markk's Avatar
markk
just changing the diff mount aint gonna solve ya problem m8 !!
its all about the full package , the biggest offenders are them fookin shit big fook off bushes on the front of the beam , if you put a bar on them you will find they will actually lift about and inch up and down - these need to go , full alluminium units are req in there , then we have the rear mount these too have masses of play, this also needs to be solid mounted , the GRPA unit was a full diff back plate with the solid mount cast into it with the 4 bolt holes up to the chassis
tramp/axle bounce is very undesirable, the grip you loose is massive , this needs to be sorted, the reason that you sometimes get this phenomenon is that either you have got enough grip on the road surface that the force(propulsion) has taken the easier option than sending the car forward , so hence the traction breaks and the wheels come off the ground, when you dont get it (at full chat) is because the wheel will be spinning on the tarmac , hence the force has another easy route (no road grip) hence the massive wheelspin!! ok so far ????
as for the coil over job , springs and valving are another major part in the prevention of this , if you have no other movement on the rear of the car , then its down to the shockers , what coil overs have you got ??
i would poss suggest that the springs are too soft , and the combination of the 'bump' part of the valving is very low allowing the force of teh spring to be overcome and the fact that this 'bump valving' isnt enough to stop the oil flowing through the valves hence you will get the tramp.
if you are talking about what i call 'road going' coil overs then these are really only marginally better than uprated shocker/spring setup all you get is adj ride height, these manufacturers have to keep the 'road' element of teh spring/valve combination for drivability !!
hth
mark
Old Oct 17, 2004 | 11:25 AM
Ian M's Avatar
Ian M
mine used to do this on coil overs so i changed my suspension. i had new springs made bought new konis and had the rears revalved by a suspension specialist straight away it doesnt do it now and has very good traction from a standing start i also dont run a rear anti roll bar.
Old Oct 17, 2004 | 11:58 AM
Jim Galbally
so 1st thing to try is to set the rear shocks softer then?
mine are almost at full soft, and the car's almost std rideheight too...
now i spose its time to look at bushes, mounts etc. etc.?
Old Oct 17, 2004 | 02:13 PM
POPEYE's Avatar
POPEYE
FAIRY CAKE
solids bushes first jim going by what mark says
Old Oct 17, 2004 | 03:23 PM
Ian M's Avatar
Ian M
yeah great if you want to go to the dentist every week
Old Oct 17, 2004 | 03:30 PM
R4N SS's Avatar
R4N SS
mine did this but then i changed the wheels to and now i can spin it with no thud noises.
Old Oct 17, 2004 | 04:00 PM
markk's Avatar
markk
ian m,
hes already using coil overs so the next step to stop this happening is this !
Old Nov 22, 2004 | 11:25 AM
Jim Galbally
ok its REALLY pissing me off now
most of what you said mark went over my head to be honest
ok so, i have rear coilovers etc.
whats the 1st thing i should try?
Old Nov 22, 2004 | 11:30 AM
RichardPON's Avatar
RichardPON
I used to get this ALL the time at the Pod.
Used to be so violent, I thought my teeth were going to drop out!
Old Nov 22, 2004 | 11:31 AM
Jim Galbally
mine's that bad rich... EVERY time it wheelspins in 1st it does it on the old suspension i only got it VERY occasionally...
Old Nov 22, 2004 | 12:03 PM
gearboxman's Avatar
gearboxman
So I'll be needing to fit some tramp bars on the Transit then, or just put some more gearboxes in the back
Old Nov 22, 2004 | 12:15 PM
SPADGE's Avatar
SPADGE
Sorted my problem by selling the car
Old Nov 22, 2004 | 01:19 PM
Jim Galbally
dont think i'll be going down that route
if i have knackered bushes/mounts shall i get em replaced with poly ones?
Old Nov 22, 2004 | 05:00 PM
markk's Avatar
markk
Jim Galbally,
jim provided you got spherical joints in the rear arms or at worst new bushes , then change the large beam mounting bushes for somat really hard and that wil stop tha happening !!
Old Nov 22, 2004 | 05:43 PM
alan rainbow's Avatar
alan rainbow
mine did this on coil overs group a ledas fully rose jointed and when i poly bushed the back end it went away so more likly to be bushes as mark says
Old Nov 23, 2004 | 12:20 AM
Fastmaul's Avatar
Fastmaul
K155MYRS
My XR used to do this aswell, it's all about the rear suspension settings. I had full Poly bushings and coilovers.
