going to buy a saphy- what shall i look for
Old Feb 12, 2008 | 01:54 PM
Tank Mike's Avatar
Tank Mike
Default going to buy a saphy- what shall i look for
Im off to buy my first cossie today. its a late spec saph. any idea what goes on them and what i should check.
thanks
mike
Old Feb 12, 2008 | 02:13 PM
LHD220Turbo's Avatar
LHD220Turbo
4x4 or 2wd, big difference!
Old Feb 12, 2008 | 02:25 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Buy one with a recent engine rebuild, documented. Don't be impressed by "FSH" on an 80k car or similar - you buy it just in time for it's first rebuild LoL.
Watch for rust
Old Feb 12, 2008 | 02:26 PM
rog's Avatar
rog
Well if it's late spec I'd say it's a 4x4?
Lots of points to be honest mate, but one for me would definately be the strut tops in the engine bay(very common problem), once they start rusting between there and the inner wing it's a pain in the arse to sort. Also Rust underneath (chasis legs @ rear) obviously, but should be ok if its a later car, also check for rust in the spare wheel well in the boot aswell. Most other rusty bits should be fairly easy to spot, now on the mechanical front, how compotent are you?
Old Feb 12, 2008 | 02:27 PM
rog's Avatar
rog
Watch for rust
Good point, wish I'd gone 4 one with an engine build, it will save u a LOAD of hassle if you just want to enjoy the car
Old Feb 12, 2008 | 02:36 PM
rog's Avatar
rog
This might help a bit, but it is for an early 2WD saph.
http://www.fastfordmag.co.uk/resourc...buy_2wd_sc.pdf
Old Feb 12, 2008 | 02:44 PM
silky16v's Avatar
silky16v
Get on That!
take some1 with you who knows there stuff about 4x4 saphy's
Old Feb 12, 2008 | 04:28 PM
Csm's Avatar
Csm
And it all depends who built the engine !!!!
Its ok saying its had an engine rebuild but then there are mechanics out there who have slept with a mechanic and couldnt build a model car never mind a fookin engine
Get someone in the know cos if you buy a shitter it will cost you severely
Old Feb 12, 2008 | 05:20 PM
Just make sure the body work is good. I wouldnt buy the first 1 you see either. I looked at 3 cossies n i bought the 3rd 1 i seen. I love my car but i kick myself cause i think i should of looked at a few more first. Mine came with a full service history. I had a fault with my car where it kept cutting out . It turned out to be the fuel filter full of poo. This had never been changed in its life.
tankybaby66
Feb 6, 2016 02:24 PM
Fil
Sep 30, 2015 12:08 PM
muz
Sep 30, 2015 08:29 AM
Nick 172 Sport
Sep 28, 2015 07:21 PM
