water getting into the oil
if its a hcs engine then its a common problem with breathers basicly there shite,give them all a good clean and also replace the oil cap as this has its own filter witch is also shite,if its a cvh then again could be down to blocked breathers so a good clean and see how it goes if it still the same then it may be headgasket problems or could just be down to cold mornings and condensation.hope this helps
