rear lights
Old Feb 11, 2008 | 11:11 AM
craig todd's Avatar
craig todd
Default rear lights
when braking whilst my side lights are on, the offside side light goes off, comes back on when foot brake is released. someone's said that it will be the earth and it will need cleaning up, anybody know where the earth is for the rear lights, its a 2wd saff cosworth.
thanks in advance.
Old Feb 11, 2008 | 02:22 PM
Std ford problem not just on sierra's.
The earth is a brown wire that goes in the multi connector going to each back light.
The pins on the rear bulb holders are galvanised but still rust and give these problems, these pins are the ones the connector plugs into from the loom.
You can buy new cheaply if needed new rear light bulbholders, each side, but may be ok with a clean up.
The best bet though is to make up a seperate earth wire for the lights/bulbholders, drill a 3/4mm hole in the earth track on the bulbholder, and stick a wire through and solder in place, then ring terminal on the other end to a good earth on body/lock bolts etc job done.
I always hard solder my light bulbholders in so don't suffer problems ever then.
Old Feb 11, 2008 | 03:06 PM
craig todd's Avatar
craig todd
thanks tabetha, i will do it after tea.
craig
Bailes1992
Sep 3, 2015 02:17 PM
mint_s2
Sep 2, 2015 08:58 AM
RsS2daz
Aug 14, 2015 05:26 AM
sridgett
15
Aug 3, 2015 07:26 PM
