Window trim on a saff
Old Feb 10, 2008 | 10:20 PM
Saaamon's Avatar
Saaamon
Default Window trim on a saff
Im changing the trim round the window to the black ones from an xr4 and i need to take the trim off both cars then refit the black ones to my saff, can anyone tell me how hard this is and any tips on how to do it? Cheers
Old Feb 11, 2008 | 12:02 AM
davy 6457's Avatar
davy 6457
rears are handy u dont even have to take the door panel off just remove the sail panel and pull the rubber out make sure u dont bend it cos they dont straighten very well.
for the fronts remove the door panel and unscrew the mirror you should again be able to pull the trim out of place. when puttin in the new trim you should really drop the window winder out of its place and fit it in. you can do it with the winder in place but its fiddly.once seated in refit ur winder and rebuild your door up. make sure u try ur windows first though to make sure the seal isnt snagin. hope this helps
Old Feb 11, 2008 | 12:12 AM
Saaamon's Avatar
Saaamon
cheers 4 that i'll let you no how i get on, doing it at the weekend i think
Old Feb 11, 2008 | 07:01 AM
cossie04's Avatar
cossie04
I`ve got the sierra now Si, window rubbers are good too. Will start stripping it soon m8...
Old Feb 11, 2008 | 05:06 PM
Saaamon's Avatar
Saaamon
nice1 mate chrome trim looks wrong lol
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
cossie330
Sep 27, 2015 04:13 PM
