coilovers
Old Feb 10, 2008 | 07:22 PM
cossie0_4's Avatar
cossie0_4
Default coilovers
will a set of coilovers off a three door rs500 fit a 2wd saph these are the rears that i want to fit cheers
Old Feb 10, 2008 | 07:26 PM
155lee's Avatar
155lee
only the 4x4 fronts from a sapphire or escort cos wont fit a 2wd cosworth as far as im aware!
Old Feb 10, 2008 | 07:30 PM
cossie0_4's Avatar
cossie0_4
what about the rears m8
Old Feb 10, 2008 | 09:16 PM
col cos1's Avatar
col cos1
rears are all the same throughtout the cosworth range mate
Old Feb 10, 2008 | 09:23 PM
155lee's Avatar
155lee
i know a 2wd standard sapph,like any cooking model has a wider bracket on the rear arm where the shock bolts on.but all the cosworths are the same!
Old Feb 11, 2008 | 07:41 AM
As said std sierra lower rear shock mount has shorter eye, but longer ones can be cut down.
All rears as said the same though on cossies.
jessie_rs
62
Aug 6, 2019 09:27 PM
mk1turboestate
Dec 2, 2015 08:31 PM
S3an
Sep 26, 2015 11:39 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
S3an
13
Sep 13, 2015 10:01 AM
