Getting wires/pipes through the firewall to the dashboard
Old Feb 9, 2008 | 03:00 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Default Getting wires/pipes through the firewall to the dashboard
Just about to install some gauges and other stuff, need to get wiring through the firewall, sounds easy - but what's the easiest way of doing this???
Old Feb 9, 2008 | 03:50 PM
AndyPen's Avatar
AndyPen
On 2 doors its easy through the wiring grommets and I've seen them go through by the speedo. On mine though to keep things tidy I went through the passenger side big grommet under the battery tray. Quite easy to see from underneath and ideally situated for the oil pressure guage location.
Old Feb 9, 2008 | 06:36 PM
Buy some NET CURTAIN wire stuff, the stuff about Ł1 from diy shops and this makes and excellent pull through, I use it all the time, as said big grommet is a good place but make sure you put some sealant around the hole you have to make in it.
Old Feb 10, 2008 | 06:10 PM
AndyPen's Avatar
AndyPen
Yeah neat trick that
Old Feb 10, 2008 | 07:29 PM
155lee's Avatar
155lee
on mine there was a spare hole in the big grommet.used that!
andyrs1600i
Apr 29, 2026 03:21 PM
155lee
Oct 24, 2015 11:11 AM
andyrs1600i
Aug 30, 2015 07:21 PM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
TrickyDicky
11
Jul 15, 2004 02:46 PM
