escort mk6 gti ideling problem ?
Old Feb 9, 2008 | 01:17 AM
spi escort gti's Avatar
spi escort gti
Default escort mk6 gti ideling problem ?
im not haveing mutch luck with my ideling ?
my car ticks over dead lumpy just on tick over but if i drive it
eg when i come to stop and slow down it stays at 2000 rpm
its reail pissing me off
the crank case air flow sensor behind the manifold it a black box could it be this if i take the rubber vacume pipe off located on the right hand side on the manifold tick over goes worse but if i block the pipe with my finger it tick over normal
does this mean the black box thing is what i need to replace
im getting reail stuck with what it is plz help has anyone got a idea what it will be ?
Back to top
Old Feb 9, 2008 | 12:03 PM
Phil2002's Avatar
Phil2002
more than likely the idel speed control valve is getting stuck if the car holds it revs. as for running lumpy could be a few things plugs, lead, coil pack etc.
idel speed control valve is bolted to the underneth of the in let manifold will have a black 2 pin plug on it.
The Ka suffers really bad from the idel valve fuc*ing up and holds the revs up.
Hope this helps.
Old Feb 9, 2008 | 04:25 PM
Wardy257's Avatar
Wardy257
Check and clean the ISCV first.
Vincereese
Jun 1, 2023 09:14 AM
Kyle Langford
27
Aug 5, 2019 07:54 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
