Few Escort Cossie Questions
Old Oct 16, 2004 | 03:21 PM
Skiman's Avatar
Skiman
Default Few Escort Cossie Questions
What psi can a standard small turbo be raised to running a superchip? also what can the standard actuator run to?
Old Oct 16, 2004 | 03:24 PM
steviecossie's Avatar
steviecossie
is it a stage 1 chip or more
Old Oct 16, 2004 | 03:25 PM
Skiman's Avatar
Skiman
Stage 1
Old Oct 16, 2004 | 03:28 PM
TrevCos's Avatar
TrevCos
Stage 1 chip max about 280bhp, that's what mine was running. If you want much more you're into a big turbo conversion and big money, but I think the stage 1 is perfectly adequate and won't cost you anything more on your insurance if you're with Dominion.
Old Oct 16, 2004 | 03:30 PM
steviecossie
the stage will be fine you shouldn,t need to change too much but if u want to go for any more than that get some cash together and get a big turbo conversion to be on the safe side.
Old Oct 16, 2004 | 03:39 PM
Skiman's Avatar
Skiman
I dont want anything more than this....what psi can the turbo and the actuator run?
Old Oct 16, 2004 | 03:42 PM
steviecossie
you will need to get it set up to find out.
Old Oct 16, 2004 | 03:44 PM
Skiman's Avatar
Skiman
i know - but roughly what are you talking about 16/17psi standard?
Old Oct 16, 2004 | 03:51 PM
steviecossie
maybe about 18 psi are you using the car everyday? and make sure it gets set up properly you don,t want any problems
Old Oct 16, 2004 | 03:55 PM
Skiman's Avatar
Skiman
ill probably set it to around 17psi to be on the safe side,then ill take it up to the RS specialist over here to get him to set it up.
Old Oct 16, 2004 | 03:59 PM
steviecossie
better being safe than sorry
Old Oct 17, 2004 | 11:54 AM
Azrael's Avatar
Azrael
Mine with superchips is running about 1.5 to 1.6 bar from new with no major engine problems (apart form failed headgasket).
Old Oct 17, 2004 | 01:25 PM
SEAN's Avatar
SEAN
Who is the RS specialist over here in N Ireland??
Looking to get some work done on my Escort Cossie
Cheers Sean....
Old Oct 17, 2004 | 02:17 PM
rapidcossie's Avatar
rapidcossie
18 psi on a t28 surely not?
Old Oct 17, 2004 | 02:41 PM
Skiman's Avatar
Skiman
T25 turbo is it not?
Old Oct 17, 2004 | 03:17 PM
The Youth.'s Avatar
The Youth.
mine runs at 18 psi with no problems
stage 1, superchips capsule
did have to turn the boost down when the decat magnex was fitted,it went up to 21psi as soon as it was fitted!! just showed how harder the turbo was having to work to overcome the restriction in the cats/standard exhaust.
steve
Billy_RS
16
Oct 11, 2025 09:41 PM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
stickyslick
14
Aug 10, 2015 06:27 PM
