82 or 88 degree thermostat for 4x4 sapphire
Old Feb 8, 2008 | 08:54 PM
jemis's Avatar
jemis
Default 82 or 88 degree thermostat for 4x4 sapphire
Buying a new thermostat and was wondering whitch one to go for and why.
N
Old Feb 8, 2008 | 09:44 PM
charlie luciano's Avatar
charlie luciano
If it were me I would say the 88 degree one because as you know the wiring fitted by ford for the cooling fans is shite and not up to the job, when the fans keep kicking in, in traffic for example the wiring gets fucking hot and tends to melt, if the fans kick in at 82 degrees they will be on more often hence heating up that wiring
so my advice stick to 88 degree stat, also keep an eye on your temp gauge as 4x4 stats are notoriously unreliable
Luciano
Old Feb 8, 2008 | 10:40 PM
jemis's Avatar
jemis
My cooling fan system has been rewired and uprated and has a manual overide switch on the dash to switch the fans on anytime.
Old Feb 8, 2008 | 11:05 PM
charlie luciano
If that is the case you might want to consider an 82 degree stat then
Luciano
Old Feb 8, 2008 | 11:31 PM
jemis's Avatar
jemis
Actually just did about 1/2 hour ago from ggr's ebay site along with some other service parts.
Old Feb 8, 2008 | 11:42 PM
charlie luciano
Also you'll have to forgive me, its a little late and I'm a little tired the fan switch is what kicks the fans in and not the stat once water temp hits 87-88 degrees in comes the fans, I not too sure of the benificial difference between the two stats
Luciano
Old Feb 9, 2008 | 03:55 PM
AndyPen's Avatar
AndyPen
As I understand it the 82 degree was initially a special for the rs500 as the bigger intercooler partially blocked the rad and they overheated during testing on tickover. If you are going to fit one of these bigger rs500 type intercoolers sometime it would make things run cooler.
Nov 1, 2015 06:53 PM
Rsmat
89
Oct 12, 2015 07:50 AM
Iain Mac
Sep 30, 2015 09:39 PM
Fil
Sep 30, 2015 12:08 PM
The Enigma
Sep 29, 2015 10:31 AM
