Hunting on tickover
Old Feb 8, 2008 | 06:27 PM
PewteRS's Avatar
PewteRS
Default Hunting on tickover
My car is hunting on tickover and pissing me off................any ideas what causes this ??
Old Feb 8, 2008 | 06:40 PM
krisberic's Avatar
krisberic
most likely the idls speed controll valve, mine was doin same so i cleaned it aswell as changin cts and all probs sorted. Could aso be one of them small vac pipes thats split. just have a look and listen.
Old Feb 8, 2008 | 09:02 PM
PewteRS's Avatar
PewteRS
I'll get a cts...........worth a go for Ł15
Does the iscv come apart and what's the best to clean the it with?
Old Feb 8, 2008 | 10:36 PM
RS Bowk's Avatar
RS Bowk
I'd say carb cleaner mate
Mines hunts but only ever so slightly not aure if this will cure it i will give it a go.
Old Feb 9, 2008 | 06:58 AM
redrsmk5's Avatar
redrsmk5
could be a slight air leak mate, if youve taken anything off check everything you have put back but more than likely iscv
Old Feb 9, 2008 | 10:52 AM
AJC's Avatar
AJC
when mine did it, it was the ECU
Old Feb 9, 2008 | 02:56 PM
PewteRS's Avatar
PewteRS
It seems to be worse when the engine warms up. I've got mikalor hose clamps but i sure i remember these caused leaks . I'll chack all the things suggested though.
Thanks for the advice
Old Feb 9, 2008 | 05:25 PM
PewteRS's Avatar
PewteRS
How the hell do you get he iscv out
Old Feb 9, 2008 | 08:56 PM
bigpower's Avatar
bigpower
I was thinking that too! tried and gave up, but since trying it seems better now!LOL
Old Feb 10, 2008 | 12:45 PM
AJC's Avatar
AJC
PewteRS
just disconnect it first, if it does not stp hunting, its not your ISCV
Old Feb 10, 2008 | 01:51 PM
PewteRS's Avatar
PewteRS
Originally Posted by AJC
PewteRS
just disconnect it first, if it does not stop hunting, its not your ISCV
Old Feb 10, 2008 | 03:56 PM
PewteRS's Avatar
PewteRS
Ok now i disconnected the ISCV when it was hot and hunting on tickover and it stopped and idled nice.
So how the fuk do i get it out to clean it
Old Feb 10, 2008 | 04:09 PM
R5COS's Avatar
R5COS
my old saff used to do the same i took da whole elbow off the saff to get off the iscv, very tricky to get off other wise its worth doing it this way as you can replace the gaskets to as no boby every changes them one of them could have a leek, get the dearest carb cleaner you can two tins off spray it on and catch it in a bowl and leave the iscv in it over nite. job done
Old Feb 10, 2008 | 08:52 PM
PewteRS's Avatar
PewteRS
I replaced all the gaskets with cometic not too long ago so tbh i dont really want to strip the inlet again
Is there no way it will come off without removing the throttle body?
Old Feb 10, 2008 | 09:29 PM
THE RADMAN's Avatar
THE RADMAN
just remove the 2 little bolts,pull like f*ck, you cant turn/twist it as it has 2 little locating lugs but if its really tight then you can always wrap it with masking tape to protect it and get some big grips on it for extra leverage theres only a rubber o ring in there try and get some wd40 around the edge as well
Old Feb 10, 2008 | 09:55 PM
PewteRS's Avatar
PewteRS
Brute force it is then
Cheers Nick
Old Feb 11, 2008 | 10:43 AM
PewteRS's Avatar
PewteRS
Masking tape, grips and WD40 and out came out easy.....Cheers Nick
I got it soaking in carb cleaner now so lets hope it does the trick
Old Feb 11, 2008 | 02:39 PM
THE RADMAN's Avatar
THE RADMAN
Old Feb 11, 2008 | 03:20 PM
bunjeeman's Avatar
bunjeeman
Did you take the ISCV apart? I find that it's best to take it apart and soak the parts and give them a good clean and them put it back together again. There should be 4 parts in total, 2 springs (remember which one goes where), a nut , a metal collar and the washer.
Best to measure how far down the nut is on the threaded shaft before you dismantle as this can affect your idle level.
Works a treat on mine.........
Remember to give the runner o-ring some sillicone grease or WD before you put it back in, much easier to remove the next time.
Old Feb 11, 2008 | 04:45 PM
PewteRS's Avatar
PewteRS
I didn't know it came apart but i've put it back in and all seems fine. The car has not been driven since early spetember so i think it could do with a good run now so it will have a 200 miler (each way)coz i've booked it into Motorsprt Developments for a set up and closed loop
Thanks for all the spot on advice guys
Old Feb 11, 2008 | 05:33 PM
JanDK's Avatar
JanDK
For sure the best way to do it. I can recommend you to grease the ISCV piston with a little siliconegrease to. It worked MUCH better on my valve.
Old Feb 11, 2008 | 06:12 PM
bunjeeman's Avatar
bunjeeman
Glad to hear that all is well now, good luck at Motorsport Developments, please say "hi" to Stu for me....... I just received a bunch of goodies from him, he sent it to me in Hong Kong!!!
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
cozzy jeff
Aug 31, 2015 04:14 PM
dlwarrior
Aug 5, 2015 10:19 AM
