The only problem you get is from them catching on full lock, but what car doesnt with bigger wheels on, apart from that no problems. I would say you only need the spacers on the back as they sit nicely in statue with the arch but the fronts catches on the suspension so your 4mm spscers should be adequate hope this helps.
