iscv
I was going to clean my iscv today but it doesnt come off. So where is it? I un did the 2 screws and the plug but it didnt come out do i have to take the other 4 screws out and un do the whole lot? where the boost pipe goes to?
no m8 that sounds like the throttle housing m8 undo the 2 screws grip tite and wiggle or if really tite try 2 gently lever her up with a screw driver. just dont play with the adjuster inside as there locktited in position or if you do re loctite it otherwise it could come loose and drop in2 1 of the cylinders and mess up a piston or worse m8.
you could always give it a gentle tap with a rubber hammer and spray a little wd40 around it and just keep wiggling it it will come out if not brute force and ignorance but you mite damage the icsv and there not cheap m8
I am now thinking i am attacking the wrong thing, this is it isnt it?
You undo the 2 screws indicated then take the cover off and pull it out but it wont budge i have had mole grips on it but only moves a bit.
DixieTheKid
11
Jun 6, 2020 11:20 AM
