gas fitter / CORGI local to Reading/Bracknell - SORTED
Old Feb 7, 2008 | 03:26 PM
foreigneRS's Avatar
foreigneRS
Testing the future
Default gas fitter / CORGI local to Reading/Bracknell - SORTED
i need a small job doing to move the gas meter slightly as it's in a stupid place. anybody local to binfield (between Reading and Bracknell) that can do it?
Old Feb 7, 2008 | 05:10 PM
BIGMATT1's Avatar
BIGMATT1
if you need the inlet side moving you need to contact national grid gas, you can do it on line, corgi reg guys normally only can work from the emergancy control tap, or ask an nat grid/ transco guy if hes intrested in a bit of cash work next time you see them about
Old Feb 7, 2008 | 06:49 PM
foreigneRS's Avatar
foreigneRS
Testing the future
thanks for that
it would be moving the meter changing the pipework only after the emergency control tap
Old Feb 7, 2008 | 07:53 PM
simhopper's Avatar
simhopper
yeap you will have to contact your supplier and request it to be moved
its usually a fixed fee regardless of distance,last time i inquired it was around 400
Old Feb 7, 2008 | 07:56 PM
brs's Avatar
brs
yep it aint cheap of those robbing gits
Old Feb 7, 2008 | 08:04 PM
rigwrecker's Avatar
rigwrecker
if u see any off the gas boys digging up the road any where they might do it on the side for cash national grid is tryin to stop all overtime so they will do any thing for a bit off cash
Old Feb 7, 2008 | 08:39 PM
foreigneRS's Avatar
foreigneRS
Testing the future
that seems ridiculous i just want it moved a foot across to the left and mounting on the wall
can't the tap just be closed and the pipework modified?
Old Feb 7, 2008 | 08:59 PM
simhopper's Avatar
simhopper
that bracket should be mounted on the wall anyway as without it being fixed you can turn the meter around....allegedy
Old Feb 7, 2008 | 09:40 PM
Lee Reynolds's Avatar
Lee Reynolds
nice fuses
Old Feb 8, 2008 | 08:14 AM
foreigneRS's Avatar
foreigneRS
Testing the future
quality installation isn't it?
Old Feb 8, 2008 | 04:02 PM
Lee Reynolds
foreigneRS
you changing that too?
Old Feb 8, 2008 | 07:01 PM
325Pete's Avatar
325Pete
Problem is you'd need to remove the tap to do the pipework, so ideally you need to turn the gas off before the property. Its an easy job, just wish you were closer
Yep, I'm one of them lads who dig our roads up
Old Feb 8, 2008 | 08:20 PM
foreigneRS's Avatar
foreigneRS
Testing the future
Originally Posted by Lee Reynolds
foreigneRS
not at the moment, might move, so not worth it. but if we stay, i'll change it to add some extra circuits for outside power etc
wanted to move the meter though to make more space in the cupboard and secure it
why would you need to remove the tap? i would want it put up on the wall to the left of where it is now and higher so you could come out of the tap and do a 90 degree to the left and then go acroos and then 90 degree up again and then around the top. and then the outlet would go down the right hand side
i would seriously consider doing it myself i guess that any old joe can buy the 3/4" pipe and fittings as i have done in the past for a steam system at work. i'm used to doing pipe work as an a/c engineer and used to making things leak tight.
Old Feb 8, 2008 | 08:51 PM
escossie's Avatar
escossie
You could always try telling them that your gas meter is fitted to close to the electrics as the meter & pipework should be at least 150mm away. With a bit of luck they will move it for free as the meter is much newer than the electrical installation.
Old Feb 9, 2008 | 10:03 AM
foreigneRS's Avatar
foreigneRS
Testing the future
good idea - i was also thinking of just telling them that it is not installed properly as the bracket is not fixed to the wall and the meter can turn and i'm concerned about it developing a leak
Old Feb 9, 2008 | 02:22 PM
escossie's Avatar
escossie
its a fairly new meter & should not have been fitted like that -probably done by contractors doing it on a fixed price per job. Just get them out to look at it & they should sort it free of charge.
Old Feb 10, 2008 | 09:29 AM
foreigneRS's Avatar
foreigneRS
Testing the future
escossie i hope so
who do i contact? my supplier, npower, or british gas?
Old Feb 10, 2008 | 10:16 AM
escossie's Avatar
escossie
It gets very complicated now but i think you need to contact your supplier & they contact national grid to do the work. If its not down to your supplier they should be able to give you a contact number.
Old Feb 10, 2008 | 12:41 PM
foreigneRS's Avatar
foreigneRS
Testing the future
thanks for the advice
Old Feb 11, 2008 | 11:45 AM
foreigneRS's Avatar
foreigneRS
Testing the future
sorted - phoned national grid and a fella came out after a couple of hours and sorted it for free
still not the best installation, i would have done it a bit tidier, but it's making the best of a bad setup where the pipes go through the floor
Old Feb 11, 2008 | 12:33 PM
tsutton's Avatar
tsutton
boeb
Jan 9, 2020 05:11 AM
Oranoco
12
Oct 2, 2015 02:18 PM
Kam B
Sep 30, 2015 01:32 PM
