escort gti mk6 a nuther problem ideling ?
Old Feb 7, 2008 | 10:22 AM
spi escort gti's Avatar
spi escort gti
Default escort gti mk6 a nuther problem ideling ?
think my car falling bits
when driveing the car only till temp gets hot then im haveing troubel with ideling it keeps staying on 2 on the rev dile
does it all time at lights and stoping anywer
iv checkt plugs clead all conections up to all sencers
checkt for any vacume pipes loose and their is non
iv put petrole injectore cleaner in threw tanx /red ex
cleand carp im lost for any other things to do ?
anyone any iseas again
Old Feb 7, 2008 | 11:37 AM
spi escort gti
can anyone help ?
Old Feb 7, 2008 | 11:41 AM
BM08's Avatar
BM08
Maybe nobody can read it?
Sorry mate, why dont you use a spell checker?
In answer to your question it will be the idle control valve.
I recently had idle problems, but i took it to my local mechanic and he sprayed something into it and that was it, seems to be fine now, and i was only there 5mins and he didnt charge me
Old Feb 7, 2008 | 12:14 PM
spi escort gti
do you no wer this is located ?
Old Feb 7, 2008 | 12:35 PM
BM08's Avatar
BM08
He took off the air filter tubing, the bit that goes from the air filter to the engine and it was underneath this
Old Feb 7, 2008 | 12:53 PM
spi escort gti
do you mean the black block thing at the side of the carb
Old Feb 7, 2008 | 01:01 PM
Bungle's Avatar
Bungle
It's located under the inlet manifold and is a cunt to get at, I've got to do mine again soon as my idle is creeping up more each day
Old Feb 7, 2008 | 01:04 PM
spi escort gti
i geuss the starter and brackets have to come out to get to it will it not
me easya tacking the inlet off ? how mutch are these idel valves are they easy to fit ?
god dam cars
Old Feb 7, 2008 | 01:07 PM
BM08's Avatar
BM08
I watched the mechanic, all he did was remove the tubing which took no more than 30 seconds, then he was spraying something down there.
whatever he did worked anyway
Old Feb 7, 2008 | 01:14 PM
spi escort gti
well i need do something becouse its getting on my tits
does anyone no what that black box at the right hand side of the carb is for i thort that be the idel contole valve ?
Old Feb 7, 2008 | 02:45 PM
xr-stu's Avatar
xr-stu
you can get the ISCV off the plasitc inlet without taking anything else off. go from underneath with an 8mm ratchet spanner.
if that doesnt help, try coolant temp sender, only a tenner or so from ford.
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
There shouldn't be a carb on a GTi.
The ISCV is located under the inlet manifold. You can reach up from underneath fine, it's just time consuming and fiddly. Make sure you get a new seal for reassembly.
Old Feb 7, 2008 | 02:49 PM
spi escort gti
the temp sender is that on the top hose pipe near the air box ?
what is the iscv sory not up to date
do i need bie a new 1
or can i wd 40 it ?
Old Feb 7, 2008 | 02:52 PM
Dangerous Malcolm..
The temp sender for the ECU is on top of the thermostat housing. The sensor on the bottom is for the dash.
ISCV stands for Idle Speed Control Valve.
Old Feb 7, 2008 | 02:58 PM
spi escort gti
funy you say this becouse since my ideling my temp has been all over the place
so the sencer on top of the thermostat could be my ideling problem ?
becouse when its cold does not do it but soon ass it warms up starts playing up
could this sencer be broke and its telling my e c u my engine still cold so its putting more fuel threw causing it to idel all the time cos it is useing more petrole ?
Old Feb 7, 2008 | 04:03 PM
Dangerous Malcolm..
Sounds more like the ISCV, or an air leak. Then again your MAF or Lambda sensor could be fucked.
Old Feb 7, 2008 | 05:33 PM
spi escort gti
iv had a new lamber fited iv disconnected the idel contole valve dtarted to cut out so plug it back in and pickt back up so thats working
if my temp sencer down the 1 on the top of the thermostat will this effect my idel and send my temp gage all over ?
Old Feb 7, 2008 | 05:44 PM
Dangerous Malcolm..
You may get better advice on the FEOC website.
Old Feb 7, 2008 | 05:47 PM
spi escort gti
so do you not no if changeing this sencer would make a diffrence ?
Old Feb 7, 2008 | 05:52 PM
Dangerous Malcolm..
Not for sure, no. The zetec engines have a lot of known problems which can affect idle, so it's basically replace everything yourself or pay someone that knows what they're doing.
Have a look HERE, I found it usefull when I had my Escort.
Old Feb 7, 2008 | 06:15 PM
spi escort gti
nice 1 ill have a read
Old Feb 7, 2008 | 06:20 PM
sedan man's Avatar
sedan man
also is your timing bang on..i changed my iscv maf sensor throttle position sensor.spent a lot of cash and it was the timing all along
Old Feb 8, 2008 | 06:51 AM
xr-stu's Avatar
xr-stu
ive got a coolant temp sender i bought brand new from fords for my old scrote actually, sat in the garage doing fa (took it and all the other new bits off when i scrapped it - turned out to be ecu fault)
bung me a tenner on paypal and its yours mate
Old Feb 8, 2008 | 06:28 PM
Wardy257's Avatar
Wardy257
On a ZETEC?
Old Feb 8, 2008 | 11:48 PM
spi escort gti
im not haveing mutch luck with my ideling ?
my car ticks over dead lumpy just on tick over but if i drive it
eg when i come to stop and slow down it stays at 2000 rpm
its reail pissing me off
the crank case air flow sensor behind the manifold it a black box could it be this if i take the rubber vacume pipe off located on the right hand side on the manifold tick over goes worse but if i block the pipe with my finger it tick over normal
does this mean the black box thing is what i need to replace
im getting reail stuck with what it is plz help
Old Feb 9, 2008 | 12:25 AM
spi escort gti
has anyone got an idear ?
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
