frst a boost cut/ignition cut at 15 psi ways around it
fiesta rs turbo is ther some sort of boost cut or ignition cut limit of some sort as a m8 of mine whats to turn the bost up on his but says his car holds back at 15psi now if i remember they have a map sensor could he not just buy a 3 bar to fit or is there a unlimitted boost chip that can be bought
so far i have built him a engine with .5 over size fordge pistons 1.5m of the top h beam rod fully ballanced crank o ringed block ported and flowed head t34 turbo paddel clutch front mount intercooler uprated intank pump std cam
is ther a chip that you can provide to run this spec with 701 injectors stu please
gchristophi
Aug 31, 2015 10:36 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
