Tightening Sequance on Arp Stud and Nut Please
Old Feb 6, 2008 | 09:50 PM
Jasesapphy's Avatar
Jasesapphy
Default Tightening Sequance on Arp Stud and Nut Please
Does anyone know, as you obviously dont go 180 degrees as they dont stretch
Old Feb 7, 2008 | 06:20 AM
I followed the normal tightening sequence, finishing and checking after resting to 120 lb ft.
Old Feb 7, 2008 | 07:35 AM
silky16v's Avatar
silky16v
Get on That!
tighten studs to 15ft-lb into the block
then 35lb-ft, 55lb-ft, 75lb-ft, then check for 110lb-ft
thats the torque setting given to me by GGR for my GGR stud & nut kit
Old Feb 7, 2008 | 08:26 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
they are not suitable for a yb use long stud or genuine standard head bolts
Old Feb 7, 2008 | 12:35 PM
Jasesapphy's Avatar
Jasesapphy
At least give an indepth reason why.
Old Feb 7, 2008 | 12:57 PM
Nash's Avatar
Nash
Cake lover!
Because there shit
Raise the block up slightly around the holes i have heard, they can also crack the block around the front 2 studs. Then i might be talking crap but think thats what i was told Jase.
Old Feb 7, 2008 | 01:49 PM
Jasesapphy's Avatar
Jasesapphy
I know there are issues with long studding, but not normal Stud and Nut.
I cant understand how they could crack the block on normal studs there only following same holes and thread length as putting a head bolt
Jasesapphy's Avatar
Jasesapphy
I was under the impression studding is better as its less likly to damage the thread taking head bolts in and out
Old Feb 7, 2008 | 03:40 PM
They are a rolled thread so way way better than el cheapo ones.
If the block were weak enough for the mere placement of a stud to cause cracking then it would most likely self destruct the second you started it anyway.
What has likely happened in the past is some numpty has not cleared out the holes before putting in the studs, or done them up studpidly tight.
Old Feb 7, 2008 | 03:47 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
the arp studs dont allow for the expansion of the head,like std bolts...hence they can pull threads or lift or crack the block,as the head expands.
however ive used them and had no probs...but im long studding now with the t4
Old Feb 7, 2008 | 03:50 PM
Jasesapphy's Avatar
Jasesapphy
My mate Steve as ran stud and nut for 5 years know, done loads of trackdays and 80K in that time, on the same head gasket running a good Stage 3 set up on a T34 with no issues.
Old Feb 7, 2008 | 04:00 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
I actually dont know where this comes from, i have used them in many engines over the time now, so have my friends, an NO ONE has broken a block.
The arp`s are only shit if you dont mount the studs correctly, and that is if you dont clean the holes in the block and if you tighten the studs to hard down in the block, otherwise NO WAY!
First clean the threads with a thread cutter
Then put the studs in by hand, and ONLY tighten by hand
I use a normal tightning sequence 1-10
40nm
80nm
110nm
Then heat engine up to normal temperatures
Let engine cool down(till next day or so)
Then losen one bolt 45` and re tighten to 110
This is because of the headgasket and top has adapted to the pressure of the bolts and kompression, so it has to be re-tightened to match everything up again.
ALWAYS remember this cause the bolts dont stretch
Cosnada
Jan 7, 2016 05:30 PM
cossie330
Oct 7, 2015 08:22 PM
DavidK
Sep 27, 2015 02:55 PM
little bram
Sep 27, 2015 07:45 AM
IainRS1700T
Sep 25, 2015 06:44 AM
