Help - Annoying problem with my wifes puma...
Old Feb 6, 2008 | 03:25 PM
GTechR's Avatar
GTechR
Default Help - Annoying problem with my wifes puma...
The starter went on the wifes puma yesterday, so I swapped it over, now to do this you have to remove the inlet manifold, to make life easy I removed the airbox and battery box... fitted it all back and now it either really strains on tickover or it stalls when slowing down, but ticks over when you start it... now I did at one point remove the pipe in the inner wing that has some sort of box attached to it that fits on the airbox thinking it would maybe help the car breath a bit better, (why run the main air feed pointing backwards in the inner wing?) but when I started it, this happend so fitted all the pipes back up... I've gone over all the wires the various sensors and connectors, and cant see anything a miss, i'm banging my head at a wall now, just wondered if anyone had any ideas? My wife quite rightly is refusing to drive it till it's sorted as it cut out halfway across a junction and lost the power steering.
My thoughts are it could be the ISCV but other than disconnect the plug I ain't touched it.
Any thoughts, advice gratefully recieved.
Old Feb 6, 2008 | 04:29 PM
GTechR's Avatar
GTechR
Thanx for the overwhelming responce
Anyway I think i've sorted it now
Old Feb 6, 2008 | 11:20 PM
AndyRST's Avatar
AndyRST
You can clean the ISCV out with carb cleaner if its stuck.
what was it the maf sensor on the air filter box?
Old Feb 6, 2008 | 11:24 PM
mad dog younge's Avatar
mad dog younge
so you lasses cat has been giving you problems ....puma
Old Feb 7, 2008 | 12:00 AM
MK5RST's Avatar
MK5RST
Air leak on inlet somewhere, split pipe or fooked gasget
Old Feb 7, 2008 | 07:55 AM
GTechR's Avatar
GTechR
Thanx guys... I 'think' I sorted it, it's fine for now.
In a nut shell when I got the car running I sprayed WD over anywhere where I thought there could be an air leak, and there was no apparent leak, so I checked the connectors again, disconnected the ISCV and Maf, as soon as I did the car cut out straight away, so I guesed it wasn't those.
Delving a little deeper when I took the inlet manifold off there are to nipples on the throttle body one is blocked off, the other has a pipe that goes the the fuel reg, I swapped the pipe over thinking I 'may' have replaced it on the wrong nipple, and when I took the rubber cap off the second nipple it literally fell to bits... I did a temp repair with some insulating tape, and so far so good. So i'm guessing it was a massive air leak cuased by the rubber cap being fukked.
Thanx for your suggestions tho guy's I appreciate it
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
