how do you remove opening 1/4s
how do you remove the opening rear 1/4 windows? the front two screws i've done but i'm stuck as how to get the rear fixing out of the window. does the cap on the outside of the window have a screw under it?
thanks Billy
thanks Billy
if you have already removed the B pillar trim and undone the bolts on the hinge youve done the hard part.
on the rear of the window within the hinge opener there is a small roll pin. just push it out and they then remove easily.
Orion_Gav
Sep 29, 2015 04:50 PM
