CV boot on a cossie -what grease?
Oct 16, 2004 | 09:48 AM
Need to re pack the cv boot with grease. I cant get a new cv boot & oil till tuesday
what grease is the best to put in?
also, when it split, oil pissed out
would this be a seal gone and diff oil pouring out?
Oct 16, 2004 | 11:35 AM
Re: CV boot on a cossie -what grease?
CV Grease!! Its the only thing to use really. Should be able to get it from Halfords??
Doesn't sound right to me, but then I have a bean tin. I would have said that a seal has gone somewhere.
Oct 16, 2004 | 02:52 PM
I seem to remember when Tonys CV split that the grease was like oil.
Oct 16, 2004 | 02:54 PM
It was like proper thick greese. Not runny like oil.
Oct 16, 2004 | 02:59 PM
oh me corrected then.
It made enough smoke like burning oil when it went, but then you wasnt hanging about if i remember
Oct 16, 2004 | 03:12 PM
S-M1C75-A
or
SQM-1C9004-A
or
Mobil Rex E22
From memory
This is the spec advised for the rear
Oct 16, 2004 | 03:16 PM
just use normal cv grease that will be fine for it
Oct 16, 2004 | 05:22 PM
The CV joint is self contained and will only hold CV grease. The only way in for anything it through the boot so it's totally unrelated to the diff. What the oil is, is just basically CV grease which has thinned out.
Oct 18, 2004 | 12:42 PM
great, thanks Daz (and others )
Oct 18, 2004 | 12:48 PM
Dave - if you're a bit skint, just use an old bit of chip pan grease...............
oh no, shit, don't do that................... then you will have nothing to style your hair with
Oct 18, 2004 | 12:49 PM
As Daz says
Oct 18, 2004 | 12:53 PM
Quote:
no, im not
Oct 18, 2004 | 12:55 PM
pmsl @ mcpikie
Oct 18, 2004 | 01:03 PM
If you buy a FORD CV boot, it will come with the correct grease to use
Oct 18, 2004 | 01:23 PM
Quote:
Good point and messy shit it is too.....
boeb
Jan 9, 2020 05:11 AM
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
