rebuilt engine - how difficult to turn by hand?
Old Feb 4, 2008 | 09:11 PM
demolition_man's Avatar
demolition_man
Default rebuilt engine - how difficult to turn by hand?
how difficult should it be to turn a rebuilt engine by hand? i've just torqued up the crank and rods in my zetec and the zetec is stiffer to turn by hand than i expected.
compared to the engine currently in my car it is stiffer to turn, and i've not yet put the head on so there is less resistance in terms of moving parts...
please tell me this is normal
it seems like it turns freely enough but initially it is sort of "seized" then it's free, but if i leave it for a few minutes it will be stiff/seized again and then once it turns it's fine.
any thoughts appreciated
thanks a lot
Old Feb 5, 2008 | 06:08 AM
They are tight to start with when turning by hand as all the surfaces are rough on a microscopic level, certainly dry bores, or even new oiled bores are very good at causing friction, so long as crank spun freely nothing to worry about.
Old Feb 5, 2008 | 06:43 AM
zetecapri's Avatar
zetecapri
2.0 16v Turbo
as long as it turns over youre in the clear
will be stiff most probably cause the engine is dry.
Old Feb 5, 2008 | 08:28 AM
NATH-RSZT's Avatar
NATH-RSZT
have you used all the same rod bolt caps as before as my mate built an engine a while ago and he used different ones and the engine was realy stiff,
The Underdog
29
Sep 7, 2015 09:49 PM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
muz
Aug 1, 2015 06:48 AM
