turbo clocks
Old Feb 4, 2008 | 08:16 PM
adlejones's Avatar
adlejones
Default turbo clocks
hi ive got a mk 4 escort with the standard dash clocks with no rev counter and want to put s2 turbo clockes in with rev counter does anyone know if i have to change the loom.
Old Feb 4, 2008 | 08:26 PM
picky775's Avatar
picky775
shouldnt need to change the loom,but you may have to put a rev counter wire in,its a green wire if its there but doubt it will be,comes from green off coil mate.
Old Feb 4, 2008 | 08:29 PM
project rs's Avatar
project rs
you won't need all the loom but you will need to run a wire from the coil to the clocks it's the green one in standard ford stuff but it's up to you if you use a different colour, i'm not sure if you'll need to get the plugs to thet go on the back of the clocks to so you've got somewhere to conect your wire from coil to hope that helps
Old Feb 5, 2008 | 12:31 AM
cosworth_wannabee's Avatar
cosworth_wannabee
make sure u get the dials where the fuel and temp are in the right order, i got 89 spec dials for my 90 spec escort...and the temp was the fuel, and fuel was the temp lol
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
